The stereo system enters demonstration (DEMO) mode when you plug in the AC power cord (mains lead). Follow the steps below to turn off the DEMO mode. If any model-specific information is needed to complete any of these steps, refer to the operating instructions supplied with the product. Manuals are posted on our support website.
MHC Series/SHAKE Series
- For models with a DISPLAY button: While the system is in DEMO mode, press the DISPLAY button on the device or remote control.
- For models without a DISPLAY button: While the system is in DEMO mode, press the POWER button on the device or remote control.
GTK Series
- GTK-PG10: While the system is in DEMO mode, press the MIC EHO button for more than 3 seconds.
- GTK-XB60, GTK-XB72, GTK-XB90:While the system is in DEMO mode, press the W.PARTY CHAIN-LIGHT button for more than 3 seconds.
- GTK-XB5, GTK-XB7:While the system is in DEMO mode, press the
LIGHT button.
- GTK-N1BT, GTK-X1BT:While the system is in DEMO mode, press the POWER button.
Other devices
- If you are using a Home Audio device that is not listed above, refer to the product manual that came with your device.
- If you are searching for how to turn off DEMO mode on a car stereo or Sound Bar, refer to the appropriate article below:
