Article ID : 00112903 / Last Modified : 10/02/2026Print
    How to reset the Google TV™ or Android TV™ to factory settings
    Before you start
    Step 1: Power Reset
    First, try performing a Power Reset if you have not done so already. A Power Reset does not usually reset settings such as those mentioned below Warning to factory settings. If you have already performed the Power Reset, proceed to the next step.
    Step 2: Factory Data Reset
    WARNING! A Factory data reset deletes all customized settings, including channels, account information (such as a Google account ), system and applications data, downloaded apps, wired and Wi-Fi network settings, parental lock settings, and camera device's data. The TV will return to how it was at the time of purchase.
    Select your TV type:
