Various reasons can cause noise interference to the sound of Bluetooth headphones or speakers. Please check the following solutions for each cause:
Alternatively, you can visit our Sony Headphones Troubleshooting Guide for other options.
Reasons |
Workarounds | |
When using the Bluetooth device close to Wi-Fi routers, personal computers, microwave ovens, refrigerators, etc. |
Please use the Bluetooth device away from Wi-Fi routers, personal computers, microwave ovens, refrigerators, etc. in order to avoid radio wave interference. If you use a headphone set with a noise canceling function, turn the noise canceling function off. | |
When using the Bluetooth device in the pocket of the chest or pants, or a bag while listening to the audio. |
Move the Bluetooth device to a position where there is no obstacle, such as a human body, to Bluetooth communication when using the Bluetooth device in a pocket or a bag. | |
When using the Bluetooth device closes to the other Bluetooth devices. |
Turn off the Bluetooth function of the other Bluetooth devices. | |
When using the device away from the player, such as in a different room.
Keep the Bluetooth headphones/speakers as close to the Bluetooth player as possible. | |
| Case 5 |
When playing music (audio data) via the Bluetooth device placed in a case. |
Remove the case of the Bluetooth player. |
| Case 6 |
When playing music (audio data) streamed via the Internet.
Play downloaded audio contents, not stream via the Internet.
| Case 7 |
When playing music with a large file size or High-Resolution audio format. |
Change the settings Bluetooth audio streaming playback quality of your Bluetooth headphones or speaker to Priority on stable connection.
When a lot of applications are running at the same time when use the Bluetooth function. |
Quit apps which you are not using on the device to reduce the load. |
If the problem persists, try the solution bellow:
- Restart your devices.
- Reconnect the Bluetooth connection.
- If you have the Near Field Communication(NFC) function, use it to reconnect.
NOTE:
- For details on operation method, refer to the manual supplied with the product.
- If the remaining battery level of your device is low, charge the battery first and then try the procedure above.
