Applicable Model
This information is for the following model(s):
  • MSE-G500 / INZONE Mouse-A
IMPORTANT: This file is only applicable to the INZONE Mouse-A (MSE-G500). This model is not sold in all countries/regions.
Notice Before Updating
Read this section before starting the update.
This update uses the INZONE Hub app. Visit the INZONE Hub page for details on installing the INZONE Hub PC app on your computer, and refer to this page for instructions on how to update your INZONE Mouse-A (MSE-G500).
About This Download
Benefits and Improvements
  • Fixes an issue where the mouse cursor would sometimes become unstable
  • Fixes an issue where the INZONE Hub display would sometimes not update
  • Fixes an issue where accidental clicks could occur under certain circumstances
System Requirements
  • A Windows computer (Windows 11 or later)
  • An active Internet connection
  • The latest version of the INZONE Hub PC app
  • The wireless dongle must be connected directly to your computer (not via a USB hub or extension cable)
File Info
  • Name: Firmware update 1.1.12.0 for INZONE Mouse-A (Mouse)
  • Version: 1.1.12.0
  • Size: 268 KB (274 961 bytes)
  • Name: Firmware update 1.1.12.0 for INZONE Mouse-A (Dongle)
  • Version: 1.1.12.0
  • Size: 209 KB (214 448 bytes)
  • Release Date: 05-03-2026
Preparation
Check the Firmware Version
If the current firmware version is 1.1.12.0, you do not need to perform the update. To check which firmware version you have:
  1. Please connect the mouse and wireless dongle to the PC.
  2. Launch the INZONE Hub PC app.
  3. Click on Device Settings.
  4. Confirm the mouse and wireless dongle software version. If the version appears as 1.1.1.0, you can proceed with the update.
Important Notice
  • Once the update starts, you will not be able to use the mouse while performing steps 1 through 8 in the Detailed Update Procedure section below.
  • Wait for the update to finish before:
    • Unplugging the USB cable from the computer
    • Unplugging the USB cable from the wireless dongle
    • Exiting the INZONE Hub PC app
    • Turning off the computer
    If you perform any of these actions during the update, the mouse may become unusable.
  • Please connect the wireless dongle directly to the computer. Avoid connecting them via USB hubs or extension cables.
  • When connecting to a notebook PC, perform the update while the PC is connected to a power source.
  • Do not allow your computer to go into sleep or hibernation mode during the update.
Download and Install
Update Procedure
Follow the steps below to update this device:
  1. When you start an update from the INZONE Hub PC app, the update software is downloaded from the server to your computer.
    (The file size is approximately 480 KB.)
  2. Transfer the update software from your computer to the mouse and wireless dongle.
  3. Perform the mouse update.
  1. If the INZONE Hub PC app is running, right-click the INZONE Hub icon displayed in the task tray, then select Quit.
    Connect the mouse and wireless dongle to your PC while the INZONE Hub PC app is not running:
    1. First, update the mouse.
    2. Connect the mouse to the computer using a USB cable.
    3. Update the wireless dongle.
    4. Connect the wireless dongle to the computer using a USB cable.
    5. Connect the wireless dongle to your mouse.
  2. Launch the INZONE Hub PC app on the computer connected to the mouse or wireless dongle.
    If you see the PRIVACY POLICY screen, proceed to Step A below. If you see a red dot on the gear icon, proceed to Step B. All others may proceed to Step 3.
    1. If you have never launched the INZONE Hub PC app before, the PRIVACY POLICY confirmation screen and privacy settings screen will appear. Follow the on-screen instructions to proceed.
      PRIVACY POLICY screen. After reading the content, scroll down using the scrollbar on the right side of the screen to the bottom. Once scrolled down completely, the Next button at the bottom of the screen becomes clickable.
      Screen with heading [Your consent for product/service improvement/development purposes]. Below the text, there are two options arranged vertically: [Agree] and [Disagree]. Once you select either option, the OK button at the bottom of the screen becomes clickable.
    2. If the installed INZONE Hub PC app is not up to date, a red dot will appear on the gear icon in the upper right area of the screen.
      Click the gear icon to access the Settings screen, and then click Update to update the INZONE Hub PC app to the latest version.
      Note: The version displayed on the Settings screen may differ from the one shown in the image above.
  3. If a mouse and wireless dongle update is available, a red dot will appear next to Device Settings.
  4. Select Device Settings, then press the Update button displayed on the System Software Information screen.
  5. A confirmation screen for the update will appear. After reviewing the update details, press the Update Now button to begin the update.
    [Update now?] screen. After reading the Update Contents, scroll down using the scrollbar on the right side of the screen. Once scrolled down, you can click either the [Later] button in the bottom left corner or the [Update Now] button in the bottom right corner of the screen.
    Notes:
    • Update both the mouse and wireless dongle separately.
    • Once the update starts, the mouse will be unavailable until the update is complete.
  6. Once the update starts, a progress bar will appear as shown in the image below. Please wait approximately 2 minutes for the update to complete.
    Screen with the title [System Software Update]. Below the title, there is a progress bar moving from left to right, with a percentage indicator showing the completion status underneath. A  [Cancel] button is available below the progress indicator.
  7. Once the update is complete, the Update complete screen will appear. Press OK to confirm.
    Screen displaying [Update complete]. message with an [OK] button.
  8. After the update is complete, verify that the new version has been installed correctly:
    1. Follow the steps in the Check the Firmware Version section of this page.
    2. If the mouse and wireless dongle version displays as 1.1.12.0, the update was successful.
Troubleshooting
When following the steps above, an error message indicating an update failure appears.
Error message screen displaying [Update failed. Check the connection and again].
If this happens:
  1. Press OK.
  2. The INZONE Hub PC app will display the following screen. Press Update and perform the update again.
     A screen displaying the message [The update is not complete] with an [Update] button.
  3. When you press the Update button, the confirmation screen for executing the update (as described in Step 5 of the Detailed Update Procedure section) will appear. Please proceed with the update as shown.
