Article ID : 00096103 / Last Modified : 29/03/2019Print
    How to listen to music from Spotify on the receiver
    This home audio device supports the Spotify Connect feature.
    The following is required to get started using Spotify Connect:
    • Make sure that the receiver is connected to the Internet.
    • Using a computer or tablet, create a Spotify Premium account from the Spotify website.
    • Using a mobile device download the Spotify Music app.
    Steps to listen to Spotify:
    1. Launch the Spotify Music app on the mobile device.
    2. Select the desired music.
    3. Click the Connect icon.
    4. Select the Sony home audio device.
      NOTE: If the home audio device does not appear. Make sure that the home audio device and the mobile device are connected to the same Network connection.
