Playback/Recording
Can the unit playback 78 rpm records?
Bluetooth
Does this unit support BLUETOOTH connection using AAC and LDAC?
Can the unit be paired with smartphones, TVs, or computers?
The BLUETOOTH wireless communication range is short.
Supplied Items/Replacement Parts/Repair
The 45 rpm adaptor and dust cover hinge accessories have not been included.
Can styluses other than ones exclusively designed for this unit be used?
Can I replace the cartridge with the one that is not the same type as the one originally installed?
When removing the stylus protective cover, the stylus is unintentionally removed.
What are the precautions when sending the unit for repair, etc.?
