Article ID : 00248603 / Last Modified : 20/01/2026Print
    IC Recorder starts up slowly, or the data update takes a long time.
    Because the IC Recorder updates the database when the power is turned on, it may take a longer time to start if there is a lot of saved data.
    To reduce the recorder startup time, move some of the files or folders to your computer. If you are unable to move enough files or folders to your computer to reduce the startup time, you will need to turn on the recorder far enough in advance of the time you need to use it. The table below shows the approximate time to update the database:
    Number of files or foldersEstimated time
    2,500About 3 minutes
    5,000About 6 minutes
    Note: Depending on the file format, it may take longer than the estimated time.
