Article ID : 00230099 / Last Modified : 08/09/2026Print
    How to reduce wind noise on Sony headphones and earbuds when Noise Canceling or Ambient Sound Mode is on
    Issue: Wind noise may be heard when using Sony headphones or earbuds outdoors, especially when Noise Canceling or Ambient Sound Mode is turned on.
    Why it happens: Wind noise is more likely to occur when Noise Canceling or Ambient Sound Mode is enabled because these features use microphones that can pick up wind.
    What to try: Try adjusting the sound mode settings in the Sony | Sound Connect app, turning off Noise Canceling or Ambient Sound Mode when needed, or changing how the headphones or earbuds are worn to help reduce wind hitting the microphones.
    Use the buttons below to download the Sony | Sound Connect app on your smartphone.
    Visit our Support website for a complete list of app-compatible models.
    General steps to reduce wind noise
    Try adjusting the settings below using the Sony | Sound Connect app:
    • Use Wind Noise Reduction or Automatic Wind Noise Reduction, if your model supports it.
    • Lower the Ambient Sound level.
    • Turn off Voice Focus or Focus on Voice, if available.
    • Use Noise Canceling instead of Ambient Sound Mode in safe listening environments, such as indoors or on public transport.
    • Turn off Ambient Sound Mode when there is strong wind or while cycling.
    • If wind noise continues, turn off both Noise Canceling and Ambient Sound Mode. This reduces wind noise the most, but these features will not work while they are turned off.
    Notes:
    • Avoid using Noise Canceling or Ambient Sound Mode in situations where it may be unsafe if you cannot hear surrounding sounds, such as near road traffic.
    • Adjusting your position, checking the fit of your headphones or earbuds, and blocking direct airflow with clothing or hair can also help reduce wind noise.
    • If you hear sounds other than wind noise, refer to this article: Sound is interrupted or noise occurs while playing music.
    Find specific steps for your model
