What do I need?
- Micro-USB cable: Standard-A-male to Micro-B-male
NOTE: For the PHA-2A, a Micro USB cable is supplied with the product.
- USB cable or USB conversion adapter: Standard-A-female to Micro-C-male.
Connection method
For the PHA-2A:
- PHA-2A
- Walkman
- Micro USB cable (supplied)
- USB cable or USB conversion adapter(commercially-available)
Refer to the following for the connection method.
- Connect a USB cable or USB conversion adapter to the USB Type-C port of the Walkman.
- Connect a Micro USB cable to Xperia/WALKMAN/PC port of PHA-2A.
- Connect the USB cable or USB conversion adapter to the Micro USB cable.
NOTE: The connected the Walkman will not be charged even if the USB AC adapter AC-UD20 (sold separately) is used.
For the TA-ZH1ES:
- TA-ZH1ES
- Walkman
- Micro USB cable(commercially-available)
- Connect a Micro USB cable to WALKMAN port of TA-ZH1S.
NOTE: The connected Walkman will not be charged.
