Article ID : 00378014 / Last Modified : 03/03/2026Print
    Compatible smartphones and game consoles with Bluetooth connection (INZONE H9 / H7 gaming headphones)
    The connected device must support the following Bluetooth profiles and codecs to use the functions of the headphones.
    For information on supported profiles and codecs, refer to the product specifications webpage or the product manual for the device.
    • Phone calls or voice chat
      • HFP, HSP
        If the device supports HFP, you can handle calls and talk hands-free using your headphones.
    • Music playback
      • A2DP, AVRCP
        If the device supports AVRCP, you can play or pause music and adjust the volume on your headphones.
      • SBC, AAC
        If the device supports AAC, you can play music with higher sound quality compared with SBC.
    Note: Even if the Bluetooth profiles and supported codecs of the playback device match those required by the headphones, connection with all Bluetooth devices is not guaranteed.
