Article ID : 00349109 / Last Modified : 28/05/2026Print
I'm unable to set up my home theatre system or soundbar using the Sony | BRAVIA Connect app
    If your Home Theatre System or Soundbar appears in the Applicable Products and Categories of This Article section, you need to complete the initial setup using the Sony | BRAVIA Connect mobile app.
    If you connect an optional subwoofer or rear speakers, they must also be configured using the app.
    For detailed setup instructions, refer to the product Help Guide.
    If you experience connection or setup issues using the Sony | BRAVIA Connect app
    Check the following:
    Sony account sign-in fails
    Make sure you enter the correct Sony account credentials when signing in to the app.
    If the problem persists:
    1. Clear the cookies and cache in the main browser on your smartphone.
    2. Sign in again.
    For details, refer to:
    Device registration fails after Bluetooth pairing
    If Bluetooth pairing is completed but the device registration fails:
    1. Open the Bluetooth settings on your smartphone.
    2. Delete the pairing entry displayed as LE_xxxxx (model name).
    3. Perform Bluetooth pairing again.
    Wi-Fi connection fails
    The wireless connection may fail if:
    • The Wi-Fi network name (SSID) contains unsupported characters (e.g., special characters or non-alphabetical characters)
    • The router uses an unsupported frequency band (e.g., 6 GHz or even the 5 GHz band in some regions)
    An error message appears in the Sony | BRAVIA Connect app
    If device registration or connection fails and an error message appears in the Sony | BRAVIA Connect app, refer to:
    Related troubleshooting articles
    You may also find the following articles helpful:
