Article ID : 00158483 / Last Modified : 25/05/2022Print
    How long is the battery life?
    The battery life changes depending on the model and the settings. For details see below:
    • RDP-V20iP
      Approx. 5 hours of use
    • SRS-X7
      When the NETWORK OFF/ON switch is OFF: Approx. 6 hours
      When the NETWORK OFF/ON switch is ON: Approx. 3 hours
    • SRS-X11, SRS-X33, SRSXB2, SRS-X1, SRS-HG1
      Approx. 12 hours of use
    • SRS-XB3
      Approx. 24 hours of use
      NOTES:
      • For models other than the above, refer to the manual supplied with the product.
      • The actual battery life will vary depending on the temperature, the equalizer settings of the audio input device, etc.
