Article ID : 00065832 / Last Modified : 25/05/2022Print
    Unable to operate Bluetooth speaker
    In order to operate the Bluetooth speaker:
    1. Check that the system is turned on.
    2. If the POWER/HOLD switch is set to HOLD, slide it to the centre.
      Power Hold Switch
    If you are still unable to operate the Bluetooth speaker, press the RESET button found on the left side of the Bluetooth speaker with a thin object like a small pin.
    Reset Pin
    If you have followed the steps provided and you are unable to operate the speaker, repair may be required.
