Article ID : 00197663 / Last Modified : 25/05/2022Print
    What is the maximum and minimum USB storage device size that is supported by Blu-ray Disc players & DVD players?
    The Blu-ray Disc player can support the following sizes of USB HDDs, USB memories, and file systems.
    NOTE:
    • In the case of multiple partitions, only the first partition can be used. Any subsequent partitions cannot be accessed.
    • We recommend that you use a Sony external USB HDD or USB memory.
    • The Blu-ray Disc player is intended to work with third-party products, but operating is not guaranteed for all USB devices.
    • UBP-X800/M2: up to 4TB for USB HDD / up to 2T for USB flash memory
    DVD
    For the DVP-SR170 - DVP-SR370 & DVP-SR760H: your DVD player only supports FAT. For these units, it means that the supported capacity is limited to 32 GB
    YearModel NameMaximum Testes Capacity*Supported File System
    2019UBP-X1100ES
    UBP-X800M2
    USB HDD: 2TB(MBR)/4TB(GPT)
    USB Memory: 128GB
    FAT32, NTFS, exFAT
    2018
    UBP-X700
    UBP-X500
    USB Memory: 128GB
    FAT32, NTFS, exFAT
    2017UBP-X1000ES
    UBP-UX80
    USB Memory: 128GB
    FAT32, NTFS, exFAT
    2016UHP-H1
    BDP-S6700
    BDP-S3700
    BDP-S1700
    USB Memory: 128GB
    FAT32, NTFS, exFAT
    2015BDP-S6500
    BDP-S5500
    BDP-S4500
    BDP-S3500
    BDP-S1500
    USB Memory: 128GB
    FAT32, NTFS, exFAT
    2014BDP-S7200
    BDP-S6200
    BDP-S5200
    BDP-S4200
    BDP-S1200
    USB HDD: 2TB(MBR only)
    USB Memory: 128GB
    FAT32, NTFS
    2013
    BDP-S5100
    BDP-S4100
    BDP-S3100
    BDP-S1100
    USB Memory: 128GB
    FAT32, NTFS
    2012BDP-S495
    BDP-S790
    BDP-S590
    BDP-S490
    BDP-S390
    USB Memory: 64GB
    FAT32, NTFS
    2011BDP-S780
    BDP-S480
    BDP-S380
    BDP-S280
    BDP-S185
    BDP-S580
    BDP-S485
    BDP-S383
    BDP-S186
    USB Memory: 64GB
    FAT32, NTFS
    2010BDP-S770
    BDP-S570
    BDP-S470
    BDP-S373
    BDP-S370
    USB Memory: 64GB
    FAT32
