Article ID : 00081268 / Last Modified : 25/05/2022Print
    Unable to start the screen mirroring feature of the Blu-ray player
    Screen mirroring is a feature that allows you to display the screen of a compatible device (tablet, phone, etc.) on your television screen.
    NOTES:
    • This feature uses Miracast technology to create a direct wireless connection between your device and the Blu-ray Player. Your device must support Miracast (Screen mirroring) for this feature to work.
      To confirm if your device is Wi-Fi Certified Miracast devices, visit the website: https://www.wi-fi.org/discover-wi-fi/wi-fi-certified-miracast.
    • Screen mirroring does not use your wireless home network
    • While you are using Screen mirroring, your device connection to your home network will be turned off
    • iOS devices do not support Miracast, they cannot perform Screen mirroring. The inability to do Screen mirroring is a specification of iOS devices.
    • Windows 10 OS: Screen Mirroring playback may not be displayed, due to compatibility limitations with the Windows video driver.
    Follow the steps below to use Screen mirroring:
    1. Press the Home button on the remote control of the Blu-ray Disc player.
    2. Use the right or left arrow buttons to move to Input.
    3. Use the up or down arrow buttons to select Screen mirroring and press Enter.
      Screen mirroring
    4. The following screen will be displayed.
       Screen mirroring - connect devices
    5. Turn on the Screen mirroring function of your compatible device. A screen similar to the following will be displayed.
       Screen mirroring - select device
    6. Select the device that matches the name displayed on the TV screen. You only have to make this selection the first time you are making a connection. Future connections should happen automatically when Screen mirroring is turned on for both the device and the Blu-ray Disc player.
    7. The screen from your device should now be displayed on the TV screen.
