Article ID : 00086025 / Last Modified : 12/07/2018Print
    What does it mean when an "OFF-AIR" message appears on the display?
    This message means that the selected station or service is currently not broadcasting.
        You can press [TUNE + or -] to tune to another station.
    If  the "OFF-AIR" message appears continuously, please run the DAB auto tune manually following next steps.
    1. Hold down [RADIO DAB/FM-SCAN] button until "INITIAL" and "SCAN?" appears alternately on the display.
    2.  Press ENTER.
    3. Scanning will start.
    Depending on the DAB/DAB+ services available in your area, the scanning may take a few minutes.
    When scanning is complete, a list of available services is created.
    Notes: The currently stored list of available services will be cleared once the DAB auto tune process has started.
    If your country or region does not support DAB/BAB+ broadcasts, "NO SIGNAL" appears on the display.
