Article ID : 00125277 / Last Modified : 16/01/2026Print
    UPDATE and ERROR are displayed alternately on the front panel display.
    Please perform the following procedure:
    1. Disconnect the AC power cord (mains lead) from the wall outlet. Wait several minutes, and then reconnect the power.
    2. Turn on the AV receiver.
    3. Follow the instructions for Update via USB Memory again.
    If the problem persists after performing the update again, your unit might be in need of service.
