Article ID : 00129513 / Last Modified : 16/10/2017Print
    The Motion Gesture function does not work.
    Perform the swiping motion at 5 cm from the unit’s surface.
    The Motion Gesture function will not work properly if you perform the swiping motion from a distance superior to 5 cm.
    NOTE: Do not put any materials on top of the unit.
