- What to do when the Walkman is exposed to water
- Risks for your Walkman associated with water exposure
Damage caused by contact with liquids is subject to potentially expensive reparation fees. Also, there are many cases where important data was not recoverable and thus lost. The following are some examples of problematic scenarios and how to handle them.
Water damage may be caused by the following.
- Water drops
- Rain water gets into the Walkman when using it while it is raining
- Using the Walkman with wet hands
- Being submerged in water
- Spilling a drink on your Walkman
- Dropping the player into a washbasin, bathtub, toilet, water tank, etc.
- Leaving the player in clothes pocket and washing them with a washing machine
- Condensation
- Moving from a cold outside environment to a heated room causes condensation
- Going out from a cool air-conditioned room to the hot outside causes condensation
- Putting the player into a bag together with a cold plastic bottle causes condensation inside the Walkman
- Condensation inside the Walkman caused by the effect of sweat or humidity
Consult the following points on how to protect your Walkman from damages caused by liquid contact or moisture
- Do not use your Walkman with wet hands
- In the seasons when you are likely to sweat, keep the player away from your body, for example put the player in your bag
- Do not leave your player in humid places like the bathroom for a long period of time
- Avoid using your Walkman where it can easily get wet, like in the washroom
- Do not put it into your bag together with a cold plastic bottle
- Do not blow the dust out of your Walkman's ports with your breath
When your player gets wet, use a soft cloth (such as spectacles wiping cloth) to wipe the surface of the player right away.
NOTE: Thinner cloths, gasoline (benzene), or alcohol will damage the exterior finish of your player, therefore do not use those products.
If the contact with liquid is substantial, it may cause fire or electric shock, therefore stop using your player, turn off the power, and remove the connected devices right away. Even if the water drops are wiped clean, some water may have been gotten into the interior of the player. Please contact us to have your Walkman checked out as soon as you can.
NOTE:
Places where water easily gets into
Just a small amount of water may get into your player through tiny gaps. Repetition of extremely small amount of liquid contact caused by water drops or humidity inside the player will lead to internal components corrosion over time. Avoid using or leaving your player in an environment where temperature changes suddenly or a humid environment as much as you can.
[1] A gap of the buttons
[2] A gap of the exterior
[3] WM-PORT jack -
Walkman corrosion
Once the moisture gets into the body of your Walkman, the internal components may be corroded, or short-circuited. Also, the WM-PORT jack may be corroded, blue rust may appear as in the below image. In particular, if the moisture remains in the metal terminal part, it will cause the rust to appear and damage the player. -
To prevent the WM-PORT jack from getting wet
- If you are using a model that comes with a WM-PORT cap, use that cap since it will prevent the water or dust from getting in. Refer to the manual on how to install the cap.
[1] WM-PORT cap - Use a soft and dry cloth when removing dust in the WM-PORT jack. If you use a damp cloth, or blow the dust out with your breath, moisture will adhere and cause damages.
Damage caused by dirt between the case and the body of the player
If you use a case, it is recommended to remove it and clean it up frequently. Dust collected between the case and the body of the player may retain humidity and cause damage.
