Article ID : 00178643 / Last Modified : 08/06/2026Print
    How do I reconnect my Bluetooth device to the TV?
    If you have paired your Bluetooth device before, you can disconnect it without deleting the paired information. This allows you to reconnect your device to the TV without performing the pairing process again.
    Disconnect a Bluetooth device
    1. Open the  Settings screen.
    2. The following steps will depend on your TV menu options:
      • Android™ 10: Select Remotes & Accessories → select the Bluetooth device you want to disconnect → Disconnect
      • Android 9: Select Remotes & Accessories → Bluetooth settings → Registered devices → select the Bluetooth device you want to disconnect→ Disconnect
      • Android 8.0 or earlier: Select Bluetooth settings → Registered devices → select the Bluetooth device you want to disconnect → Disconnect
    Reconnect a Bluetooth device
      • Android 10: Select Remotes & Accessories → select the Bluetooth device you want to connect → Connect.
      • Android 9: Select Remotes & Accessories → Bluetooth settings → Registered devices → select the Bluetooth device you want to connect → Connect
      • Android 8.0 or earlier: Select Bluetooth settings → Registered devices → select the Bluetooth device you want to connect → Connect
    Related Bluetooth videos
