Article ID : 00200610 / Last Modified : 19/01/2026Print
    The Sound Bar and TV aren't linked through Bluetooth
    If the power of the unit does not turn on even after turning on the power of a paired TV or if the TV's sound is not output even after pressing the TV button on the remote, check the following.
    After using a different input of the unit, or if establishing a Bluetooth connection other than the TV, the unit may not automatically connect to the paired TV. Try to establish a Bluetooth connection with the TV using the following procedure.
    Ex: Pairing with Sony Android TVs:
    1. Turn the TV on.
    2. Press the HOME button.
    3. Select Settings.
    4. Select Bluetooth settings.
    5. Select Add device to put the TV in pairing mode. A list of available Bluetooth devices will be displayed after a few minutes.
    6. Select the Sound Bar from the Bluetooth menu and perform pairing registration.
    NOTE: For details, please check the instruction manual of your TV to establish a Bluetooth pairing connection.
