Article ID : 00238785 / Last Modified : 09/01/2026Print
    I cannot update the Walkman player software
    The following conditions can prevent the Walkman from being able to complete a software update. See each workaround for details:
    An error message appears, indicating insufficient storage space
    The update requires at least 2 GB of free space on the player's internal shared storage (For the NW-A300/ZX700 series, the required free space is more than 4.3 GB). If the available space is less than this value, an error message appears, indicating insufficient storage space.
    Note: The image below is an example of the error message screen that may appear when updating the Walkman using a Wi-Fi connection.
    A message 'Could not update.' is displayed in the Walkman screen
    If the error message appears, try the following:
    1. Check the free space on the player:
      1. Swipe the Home screen upwards.
      2. Select Settings.
        The amount of free space appears under Storage.
    2. Transfer the data to a computer or microSD card, and make the free space on the internal shared storage 2 GB or more (For the NW-A300/ZX700 series, the required free space is more than 4.3 GB).
    The Wi-Fi connection status is unstable
    Move to a different location with a good Wi-Fi connection.
    The battery level of the player is less than 60%
    Update the Walkman while it is charging and has at least 60% battery charge. If the battery is too low, the power may turn off during the update and, as a result, the player may not restart.
    The player does not proceed from the system update screen (only for NW-A100 series, NW-ZX505, and NW-ZX507)
    If the system update is set to Do not allow in the settings, it can't be updated. Try the following workaround:
    1. Select Settings Apps & notificationsSee all xx apps to show all installed apps.
    2. From the three horizontal dots menu at the top right of the screen, select Show systemSystem UpdatePermissions.
    3. Turn the Storage item to ON.
