Article ID : 00294073 / Last Modified : 08/09/2026Print
    The headphones sometimes turn off unexpectedly, or no sound can be heard after wearing the headphones for 15 minutes
    In the default setting, the headphones use built-in sensors to detect when you wear or remove them and automatically turn the headphones on or off as needed. If you have trouble with the headphones turning off unintentionally, check the following:
    • When you wear the headphones over a cap, cloth, a scarf, or hair, etc., the sensors may not be able to detect that you are wearing them and may turn them off. To avoid this, be sure to set the earpads directly over the ears.
      For details on how to wear the headphones, refer to the model specific Help Guide:
    • If the wearing detection still bothers you, disable the Automatic Power Off setting. You can do this using the Sony | Sound Connect app: All device settings → Power/Battery → Automatic Power Off, and select Do not turn off.
    • Make sure the headphones are fully charged.
    • If the issue is not still resolved, reset the headphones. If the issue still persists, then initialize the headphones.
      Note: Resetting the headphones will not delete the paring information, while initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
