Wearing your headphones correctly is important, both for comfort and to ensure the noise canceling function works as intended.
For tips on wearing your headphones correctly, watch the video below or follow the steps in this article:
- Make sure you are wearing the headphones on the correct ears. Check the
Left and
Right indicators on the sliders to confirm each side. The left slider also has a tactile dot you can feel.
A: Location of theLeft and
Right marks on each slider
- Extend the sliders and adjust the earpad so it covers your ear completely.
Notes:
- Make sure the earpad cushion does not bump against your ear.
- Do not use excessive force or twist the headphones, especially while adjusting the slider when folding or unfolding the headband
- Adjust the slider so the headband softly touches the top of your head.
Note: Make sure the earpad cushion does not slip off your ear.
Correct: The headband softly touches the top of your head
Incorrect: There is a gap between the headband and the top of your head
