Article ID : 00348639 / Last Modified : 06/11/2024Print
    How to reset or initialize the Wireless Headphones (WI-C200 / WI-C310)
    Reset the Headphones
    Step 1
    Plug the USB cable into the headset to charge.
    Step 2
    Press the [POWER] and the [-](volume -) button at the same time while the USB cable is still connected.
    Step 3
    The headset will reset. To charge the headset after resetting, disconnect and reconnect the USB cable.
    Initialize the Headphones to Factory Settings
    Step 1
    Turn off the headset, and ensure no USB cable is connected.
    Step 2
    Press and hold the [POWER] and the [-](volume -) button for 7 seconds or more. A blue indicator light will flash four times.
    Step 3
    The headset will initialize, resetting the settings and pairing information.
    Step 4
    Delete the headset from the list of Bluetooth products on your device.
    Step 5
    Pair the headset to your selected device again
