Article ID : 00303526 / Last Modified : 13/10/2026Print
    Can an optional subwoofer or rear speakers be connected to the HT-S2000 Soundbar?
    A Soundbar can take you to a wonderful sound experience, yet with an optional subwoofer or rear speaker set, you can get even more. A subwoofer adds more dynamic bass sound, whereas rear speakers boost the surround sound from behind you to make the sound more realistic.
    Compatible models
    The HT-S2000 is compatible with the following models:
    • SA-RS3S
    • SA-SW3
    • SA-SW5
    Note: The available models vary depending on the country or region.
    How to connect and setup
    Start with the Soundbar
    Has your Soundbar already done the initial setup? If not, install the BRAVIA Connect app and follow the on-screen guidance to complete the setup. During the setup, the app also offers you a guide to connect with an optional subwoofer or rear speakers, confirming the distance to find the best conditions.
    Adding optional subwoofer or rear speakers
    Even if you have already started using the Soundbar, it's not too late to add an optional subwoofer or rear speakers. Open the BRAVIA Connect app, and select Easy Initial Setup → Speaker Connection. You can start the connection and setup at your convenience.
    Changing the speaker settings
    If you want to connect with a subwoofer or rear speakers manually or change the wireless playback quality, check the BRAVIA Connect app. Open Settings → Wireless Speaker Connection Settings, then the Setting menu appears.
    Note: The app screens are just examples and may change without notice.
