Article ID : 00401626 / Last Modified : 13/10/2026Print
    The device name set on the BRAVIA Connect app is not displayed in the AirPlay device list
    Due to AirPlay specifications, the device name displayed will be the model name of your device, regardless of the name set in the BRAVIA Connect app.
    If you want to connect BRAVIA Theatre Bar 9 to AirPlay, for example, you can just select BRAVIA Theatre Bar 9 as the model name and go ahead with the settings.
