Article ID : 00412177 / Last Modified : 17/09/2026Print
    Unwanted noise is heard from the headphones (LinkBuds Fit)
    Before you start
    • Radio interference will affect the Bluetooth communication between the headphones and playback device. The interference is likely to occur in a crowded place, near a store's cash registers, near a microwave, near traffic lights or automatic doors, inside a crowded train or in a station, etc. To avoid interference, move the headphones and speaker closer, or set the sound quality mode to Prioritize Stable Connection in the Sony | Sound Connect app.
    • The headphones may be dirty. If foreign substances (such as earwax) build up in the air holes, no sound may come out or the volume may seem lower than usual. Regular maintenance can prevent these issues. For details on how to care for your LinkBuds Fit, refer to the article How to care for your LinkBuds Fit (WF-LS910N).
      The air hole is located on the lower side of the fitting supporter
    Solution
    1. Select the situation when noise is heard:
      Noise is heard when the headphones are exposed to wind
      To reduce the wind noise, turn Off the Noise Canceling or Ambient Sound Control. Go to step 6.
      Noise is heard while walking or running
      When the Noise Canceling or Ambient Sound Control is On, the vibration of walking or running may be transmitted from your body and cause noise. To avoid this, turn Off the Noise Canceling or Ambient Sound Control. Go to step 6.
      A rustling noise is heard when I move my body or head
      The headphones' microphone and your ear may be in contact with each other. Check the way the headphones are worn. Go to step 3.
      White noise (a small hissing noise with continuous static sound) is heard
      • When the Noise Canceling function is ON
        To avoid white noise, turn off the Noise Canceling function. Go to step 6.
      • When the Ambient Sound Mode function is ON
        The noise may be heard depending on the value of the Ambient Sound Mode. Change the value on the Sony | Sound Connect app:
        1. In the My Device tab, select Device settings → Sound tab, and tap the down arrow on the right side of the Ambient Sound Control menu.
        2. Move the slide bar to adjust the Ambient Sound level.
      Noise is heard when I push the headphones into my ears, or when I tap the headphones strongly
      This temporary noise can happen because of the Noise Canceling or Ambient Sound Control function and air-tightness of the headphones. This is normal, and not a malfunction.
      An echo is heard when I cover the headphones or pinch around the built-in microphone with my hand
      An echo in this situation is normal and not a malfunction.
      Noise is heard when the surrounding ambient noise is loud, such as when I am in a station or near a construction site.
      When the Ambient Sound Control is On, the surrounding noises can be easily heard. Turn on the Noise Canceling function, or turn off the Ambient Sound Control function.
      Noise is heard while talking on the phone
      Go to step 2.
      None of the conditions listed
      If you hear your heartbeat or breathing, or if noise occurs when you change your posture such as moving your neck, this is normal and not a malfunction.
      For other noises, go to step 6.
    2. If noise is heard during a phone call, select the appropriate situation:
      The noise occurs in my voice
      Go to step 3.
      The noise occurs in the other person's voice
      Go to step 7.
    3. Fit the headphones to your ears firmly.
      If the earbuds are not worn properly, do not fit your ears, or the air-tightness is insufficient, the phone call quality may decrease. To maintain quality, consider these factors:
      • Make sure that headphones are worn properly
      • Select the earbuds that best fit your ears. Measure the air-tightness of the earbud tips and find the optimal size of earbud tips using the Sony | Headphones Connect app
      • Make sure that the headphones' microphone and your ear are not in contact with each other.
      For additional details, refer to the How to wear the headphones properly and select the most suitable earbud tips article.
      The issue is resolved
      The size or fitting conditions may have affected the Noise Canceling function.
      The issue is not resolved
      • If a rustling noise is heard when I move my body or head, go to step 6.
      • If noise is heard while talking on the phone, go to step 4.
    4. Try speaking louder.
      The noise reduction function may have been the cause. When you speak quietly, the headphones may detect your voice as noise.
      Go to step 5.
    5. Use the headphones in a quieter place.
      The ambient sound may have been the cause.
      Go to step 7.
    6. Turn off the Adaptive Sound Control function.
      When the Adaptive Sound Control is set to On, the headphones detect your action (running, walking, etc.) and automatically switches the settings of the Noise Canceling function to Ambient Sound Control. To make maximum use of the Noise Canceling function, follow these steps to set the Adaptive Sound Control to off, and adjust the Noise Canceling or Ambient Sound Control manually.
      Note: If the Adaptive Sound Control is set to On, the Noise Canceling is adjusted and Adaptive Sound Control is activated according to your action.
      1. Turn off the Adaptive Sound Control.
        1. Connect the headphones and smartphone via Bluetooth, and then launch the Sony | Sound Connect app.
        2. In the My Device tab, check the Adaptive Sound Control status. If the status shows other than Off (Staying, Walking, etc.), select right arrow on the right side of the Adaptive Sound Control menu.
        3. Turn off the Adaptive Sound Control.
      2. Select Noise Canceling to turn the setting On.
      The headphones settings were the cause of the issue.
      Go to step 7.
    7. Try the following procedure:
      1. Set the headphones in the charging case, close the lid, wait for about 10 seconds, and then wear the headphones again.
      2. Restart the connected device.
    8. Reset (restart) the headphones.
      Refer to the How to reset or initialize the LinkBuds Fit article or view the How to reset video below:
      If your headphones model does not appear in the device list of the playback device, turn off the Bluetooth setting in the device and turn it on again, or leave the Bluetooth setting once and return to try the connection again.
    9. Initialize the headphones.
      Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
      Refer to the How to reset or initialize the LinkBuds Fit article or view the How to initialize video below:
