Article ID : 00374692 / Last Modified : 28/05/2026Print
    What type of HDMI cable should I use to connect my soundbar or home theater system to the TV?
    If applicable, use the HDMI cable that comes with your soundbar or home theater system.
    If you don't have an HDMI cable, we recommend using one of the following options:
    • Premium High Speed HDMI Cable
      • Supports 18 Gbps transmission
      • Sold separately by Sony or commercially available
    • Ultra High Speed HDMI Cable
      • Supports 48 Gbps transmission
      • Commercially available
    While Standard or High Speed HDMI cables can transmit audio, limitations or a decrease in audio quality may occur if you connect a soundbar or home theater system to a playback device that supports eARC and you want to play high-quality audio formats such as Dolby Atmos, Dolby TrueHD, DTS HD Master Audio, etc.
