Article ID : 00248796 / Last Modified : 01/10/2021Print
Portable Audio: Where to find the model name and serial number?
    Select your product type:
    WALKMAN
    Waterproof
    WALKMAN
    Head band
    Headphones
    Truly Wireless
    Headphones
    Portable and Wireless
    Speakers
    Boomboxes
    Digital Voice
    Recorders
    Radios
    WALKMAN
    Examples of correct model names: NWZ-W252, NW-E003F
    The model and serial number for Walkman Digital Music Players are usually found on the back of the unit.
    WALKMAN
    1: Model Name
    2: Serial Number
    Waterproof WALKMAN
    Examples of correct model names: NW-WS623. NW-WS413.
    The model name and serial number of Waterproof Walkman models are usually located on both sides of the unit.
    Waterproof WALKMAN
    Headband Headphones
    Depending on the headphone model, you can find the model name and serial number on the headband or inside the head-padding as in the image below
    Headband Headphones
    Truly Wireless Headphones
    The model name and serial number are located on the bottom of the Charging Case.
    Truly Wireless Headphones WF-1000X
    Portable and Wireless Speakers
    Depending on the Wireless Speakers model, you can find the model name and serial number on the bottom of the Portable and Wireless Speaker.
    Example of correct model name and Serial Number: SRS-HG1
    Boomboxes
    Example of correct name: CFD-S70
    1. The model name and serial number are located at the bottom of the product.
    2. The model name CFD-S70 is written on the outside, while the serial number label is pasted inside the battery compartment cover.
    3. Open the battery compartment cover to locate the serial number.
    Boombox model name
    Digital Voice Recorders
    Depending on the Digital Voice Recorder model, you can find the model name and serial number on the back or at bottom of the Digital Voice Recorder.
    Examples of correct name: ICD-SX2000
    1. Model Name
    2. Serial Number
    Examples of correct name: ICT-TX800
    1. Model Name
    2. Serial Number
    Radios
    Depending on the Radio model, the model name and serial number are located on the back of the unit, bottom of the unit or inside the battery compartment.
