Article ID : 00352321 / Last Modified : 11/03/2025Print
macOS Sequoia (macOS 15) Compatibility Information for Digital Camcorders
    Compatibility is verified for the following products:
    IMPORTANT: Performance is not guaranteed for all computers.
    4K Handycam Camcorders
    • FDR-AX43: Under Evaluation
    • FDR-AX43A: Under Evaluation
    • FDR-AX45: Under Evaluation
    • FDR-AX45A: Under Evaluation
    • FDR-AX60: Under Evaluation
    • FDR-AX700: Compatible
    Cinema Line cameras
    • ILME-FR7: Compatible
    • ILME-FR7K: Compatible
    • ILME-FX3: Compatible
    • ILME-FX6T: Compatible
    • ILME-FX6TK: Compatible
    • ILME-FX6V: Compatible
    • ILME-FX6VK: Compatible
    • ILME-FX30: Compatible
    • ILME-FX30B: Compatible
    • PXW-FX9T: Compatible
    • PXW-FX9V: Compatible
    Interchangeable Lens Camcorders
    • ILX-LR1: Compatible
    High Definition Handycam Camcorders
    • HDR-CX470: Compatible
    • HDR-CX680: Compatible
    • HDR-PJ680: Compatible
