Article ID : 00407031 / Last Modified : 03/08/2026Print
    Camera Accessibility Functions of ILME-FX5
    Learn about the camera's accessibility functions (user assistance functions).
    Table of Contents
    Screen Reader
    This function reads on-screen information aloud, such as text.
    Only some languages may be supported for this function depending on the model. This function is available only when the language set in the menu is supported by this function.
    Screen reader is turned on when you press and hold the MENU button while turn the camera on.
    Note: The MENU button is a circular button located on the back of the camera, at the top of the monitor, second from the right.
    Please refer to the Help Guide for setup instructions.
    Enlarge Screen
    This function allows you to magnify the shooting screen, playback screen, and menu screen display. (Some screens and objects on the display are not magnified.)
    The screen is magnified by pressing the button assigned to the magnified display function.
    While using the screen magnifier, you can move the display position using the multi selector or by dragging on the screen.
    Focus Magnifier
    This function lets you check focus by enlarging the image before shooting.
    Focus Map
    This function visually distinguishes areas that are in focus from those that are out of focus. Areas farther from the camera than the in-focus region are shown with dots in a cool color, while areas closer to the camera than the in-focus region are shown with dots in a warm color.
    Peaking Display
    This function emphasizes the outlines of in-focus areas when recording movies.
    Subject Recognition in AF
    This function detects subjects such as faces, eyes, heads, or bodies within the focus area and continuously adjusts focus to track them.
    Touch Tracking
    This function allows you to maintain focus on a subject by touching it on the screen or by selecting a subject recognition frame.
    Touch Focus
    This function allows you to adjust the focus by specifying the desired focus position through touch operation in manual focus mode.
    Multi-angle LCD screen
    The 4-axis Multi-angle LCD screen provides unrestricted angle adjustment both horizontally and vertically. This makes it easier to check the image on the LCD screen during or after a shoot, regardless of camera placement or orientation, even when you are seated.
    Custom Function
    This function lets you assign frequently used operations to easily accessible buttons and dials, allowing you to skip navigating through the menu and quickly recall functions.
