Movies recorded with File Format set to MP4 can be transferred.
For some models, movies recorded as XAVC S HD or XAVC S 4K files can also be transferred.
NOTES:
- The File Format setting that enables you to transfer movies varies by model. For details, visit Supported Cameras on the Imaging Edge Mobile (PlayMemories Mobile successor) support page.
- Movies shot in the AVCHD format cannot be transferred.
- Use an iPhone 8 or later model to transfer original XAVC S HD movies recorded in the XAVC S 4K format or with the [120p] setting.
- As movie sizes you can transfer, choose Original / 2M / VGA.
- For details on OSes and operating environments that are compatible with Imaging Edge Mobile, visit the Imaging Edge Mobile download page or support page.
