Article ID : 00091587 / Last Modified : 30/03/2026Print
    The camera takes multiple pictures when pressing the shutter button.
    The camera may take multiple pictures when you press the shutter button if a multi-image capture setting is enabled.
    Here are some scenarios when multi-image capture is used:
    Note: Available features may vary depending on your camera. Check your camera's Help Guide for details.
    • The camera is set to shoot with Superior Auto.
    • Drive Mode is set to settings other than Single Shooting and Self-timer(Single).
    • ISO is set to Multi Frame NR.
    • DRO/Auto HDR is set to Auto HDR.
    • Picture Effect is set to HDR Painting or Rich-tone Mono.
    • Scene Selection is set to Hand-held Twilight or Anti Motion Blur.
    • In the Composite RAW Sht. menu, NR Shooting Settings / Shooting for HDR is set to On.
    If you do not want to shoot multiple images, make sure none of the above settings are selected.
