Article ID : 00078779 / Last Modified : 16/01/2026Print
    Can I operate the camera while using the USB connection?
    You cannot operate the camera while using the USB connection. Disconnect the camera from the device to operate it.
    WARNING: There is a risk of data loss. Do not disconnect the camera if the access lamp is lit. The transmitting data or recorded data in the memory card may be damaged.
