Article ID : 00148934 / Last Modified : 16/01/2026Print
Does the car stereo support LDAC audio files?
How do I play by LDAC?
    Follow the steps below to play audio files in LDAC codec on your RSX-GS9 media receiver:
    1. Press and hold MENU on the remote commander.
    2. Select BT Setting.
    3. Select Audio Codec.
    4. Select Auto.
    5. Press ENTER.
    To use LDAC for playback, the connected device must also be set to LDAC. Check the instruction manual of the connected device for the setting method. Manuals are posted on the support website
