Article ID : 00256621 / Last Modified : 05/06/2023Print
    macOS Big Sur (macOS 11) compatibility information for application software
    We have checked the operation of the application software listed on this page.
    IMPORTANT: Operation is not guaranteed for all computers.
    Application SoftwareVersionApplicable Product CategoriesmacOS Big Sur (macOS 11)Notes
    Imaging Edge Desktop (Remote/Viewer/Edit)
    *64-bit only
    3.2.00Cyber-shot
    α (Alpha)
    Compatible
    PlayMemories Home™-Handycam,
    Cyber-shot, α (Alpha)
    Action Cam
    Bloggie / Webbie
    Digital Recording Binoculars
    Not supported
    Action Cam Movie Creator-Action CamNot supported
    IPTC Metadata Preset1.2.00Check the supported devicesCompatibleExcludes Mac computers with Apple Silicon
    Remote Camera Tool2.4.00Check the supported devicesCompatibleExcludes Mac computers with Apple Silicon
    PlayMemories Camera Apps-Cyber-shot
    α (Alpha)
    Under evaluationRefer to the Notice / Maintenance information section of the software website
    Imaging Edge Webcam1.1.00Check the supported devicesCompatibleExcludes Mac computers with Apple Silicon
    HEIF Converter-ILCE-1
    ILCE-7SM3
    ILME-FX3
    Compatible
    The functions of the HEIF Converter are now integrated into Imaging Edge Desktop (Remote/Viewer/Edit), Ver.3.2.00 or later.
    From now on, please use Imaging Edge Desktop (Remote/Viewer/Edit) to convert HEIF files.
    Download the latest version of the Imaging Edge Desktop software.
