Article ID : 00075244 / Last Modified : 01/06/2020Print
    A dark shadow appears at the lower left corner of images recorded with a flash
    IMPORTANT: This issue does not occur on all models.
    Depending on the condition when shooting at the wide end with the built-in flash, the lens shadow projected by the light from the flash may appear in the lower portion of the picture.
    To avoid this, try shooting as follows:
    • Move the ZOOM toward the T side and try shooting your subject from a little further away.
    • Set the Flash mode to Off and use the High Sensitivity mode.
