We have checked the operation of the application softwares listed on this page.
IMPORTANT: Operation is not guaranteed for all computers.
| Application Software | Version | Applicable Product Categories | macOS 10.14 (Mojave) | Notes |
| Imaging Edge (Remote/Viewer/Edit) *64-bit only | 1.4.00 or later | Cyber-shot α (Alpha) | Compatible | |
| PlayMemories Home | 3.6.01 | Handycam Cyber-shot α (Alpha) Action Cam Bloggie / Webbie Digital Recording Binoculars | Under Evaluation | We have confirmed that some functions cannot be used when using this app on a PC upgraded to MacOS 10.14. We are currently reviewing the situation to come up with a solution. |
| Image Data Converter |
- | Handycam Cyber-shot α (Alpha) |
Not Support | Downloading of Image Data Converter has been discontinued since September 2018. Please use Imaging Edge (Remote/Viewer/Edit) from now on. |
| Remote Camera Control | - | Cyber-shot α (Alpha) | Not Support | Downloading of Remote Camera Control has been discontinued since September, 2018. Please use Imaging Edge (Remote/Viewer/Edit) from now on. |
| Action Cam Movie Creator | 3.6.01 | Action Cam | Under Evaluation | We have confirmed that some functions cannot be used when using this app on a PC upgraded to MacOS 10.14. We are currently reviewing the situation to come up with a solution. |
| MVR studio | 1.0.03 or later | Music Video Recorder | Compatible | |
| IPTC Metadata Preset | 1.1.00 | Refer to the "Supported Devices." | Compatible | |
| PlayMemories Camera Apps | - | Cyber-shot α (Alpha) | Compatible |
