About how shutter speed can affect motion blur.
    Article ID : 00109296 / Last Modified : 13/11/2017Print
    How does shutter speed affect motion blur?
    Using a faster shutter speed like 1/250 second or faster is very good for capturing fast-moving subjects with minimal or no motion blur. This can create a still image that appears frozen in time, without any of the blurring effects associated with subject movement.
    Slower shutter speeds like 1/60 second and slower cause a blurring effect. If you want to take a picture using a slow shutter speed, it is best to mount the camera on a tripod and use image stabilization (such as SteadyShot technology) to reduce the chance of any unwanted camera movement. In a number of situations, motion blur is desirable and can provide very artistic photos.
      /support/attachments/386740/png61200.png
    • The photo on the left was shot using a fast shutter speed.
    • The photo on the right was shot using a slow shutter speed.
    IMPORTANT: There should be plenty of light when using fast shutter speeds. Because the shutter is open for a shorter duration, this limits the amount of light coming into the camera. Slow shutter speeds do not need as much light because the camera shutter is open longer, allowing more light into the camera.
    NOTE:  Shutter speed, aperture, and ISO all work together to control the amount of light that enters the camera and influences exposure.
