Article ID : 00159700 / Last Modified : 21/02/2025Print
    Transfer photos from a camera memory card to a computer.
    Follow these steps to transfer pictures from the memory card of your camera to your computer:
    Note: The steps in this article are for a computer using a Microsoft Windows operating system.
    1. Insert the memory card into the card reader of your computer.
      Note: If your computer doesn't have a compatible built-in memory card reader, use an external memory card adapter compatible with your computer and memory card.
    2. Use AutoPlay to copy the photos or copy them to your computer manually:
      • Copy photos manually:
        1. On your computer, click Start.
        2. Click Computer.
        3. Click the icon of the drive that represents your memory card.
        4. Click the DCIM or MP_ROOT folder.
        5. Click the 100MSDCF folder.
          Note: The number at the beginning of the picture folder may vary but always ends with MSDCF.
        6. Select the photos you want to copy.
        7. Use your mouse to drag and drop the photos to the desktop or another folder on your computer.
    Note:
    • Do not edit or otherwise process AVCHD movie files or folders from the connected computer or the movie files may be damaged or become unplayable.
    • Do not delete or copy AVCHD movies on the memory card from the computer. Sony cannot be held liable for the consequences resulting from such operations via the computer.
