Article ID : 00203265 / Last Modified : 29/05/2026Print
    Can the shutter sound on my camera be turned off?
    You can turn off the shutter sound on cameras equipped with the Silent Shooting function or Electronic Shutter by simply adjusting the settings.
    There are two types of shutter sounds:
    • Mechanical (from the physical shutter movement)
    • Electronic (a simulated sound played by the camera)
    The Silent Shooting function allows you to turn off both the mechanical and Electronic Shutter sounds at once.
    When using the Electronic Shutter, the mechanical shutter sound is automatically turned off, but the Electronic Shutter sound may still play unless disabled separately.
    The procedure to turn off the shutter sound varies by camera model.
    Please check the How to turn off the shutter sound for each model section below.
    Note: For models not listed below, especially if it doesn't have an Electronic Shutter, you cannot turn off the shutter sound.
    You can check how to turn off the shutter sound for each model by clicking the in the table below.
    : Available
    - : Not available / Not equipped
     How to turn it off using the Silent Shooting functionHow to turn it off using the Shutter Type switching function
    ILCE-6100, ILCE-6300, ILCE-6400, ILCE-6500, ILCE-6600, ILCE-7M3, ILCE-7RM2, ILCE-7RM3, ILCE-7RM3A, ILCE-7RM4, ILCE-7RM4A, ILCE-7S, ILCE-7SM2, ILCE-7C, ZV-E10-
    ILCE-6700, ILCE-7CM2, ILCE-7CR, ZV-E1, ILME-FX30, ZV-1F, ZV-1M2, ILCE-9M3, ZV-E10M2-
    ILCE-7SM3, ILCE-7M4, ILCE-7RM5, ILME-FX3, ILME-FX3A
    ILCE-9, ILCE-9M2, ZV-1, DSC-RX100M7-
    ILCE-1
    ILCE-1M2, ILME-FX2, ILCE-7M5, ILCE-7RM6
    DSC-RX1RM3-
    You can turn off both the mechanical and Electronic Shutter sounds at the same time by changing the camera settings as follows:
    • When using an ILCE-6100, ILCE-6300, ILCE-6400, ILCE-6500, ILCE-6600, ILCE-7M3, ILCE-7RM2, ILCE-7RM3, ILCE-7RM3A, ILCE-7RM4, ILCE-7RM4A, ILCE-7S, ILCE-7SM2, ILCE-7C, or ZV-E10:
      • MENU (Camera Settings2) or (Custom Settings) → Silent ShootingOn
    • When using an ILCE-1, ILCE-1M2, ILCE-9M3, ILCE-6700, ILCE-7SM3, ILCE-7M4, ILCE-7M5, ILCE-7RM5, ILCE-7RM6, ILCE-7CM2, ILCE-7CR, ZV-1F, ZV-1M2, ZV-E1, ZV-E10M2, ILME-FX2, ILME-FX3, ILME-FX3A, or ILME-FX30:
      • MENU (Shooting) → Shutter/SilentSilent Mode SettingsSilent ModeOn
    Notes:
    • When using the Silent Shooting function, be careful not to violate the subject's privacy or image rights. Use this function responsibly and at your own risk.
    • When using the Silent Shooting function, there are some restrictions on its use and other features that cannot be used simultaneously.
      For details, refer to this article: Are there any restrictions on the use of Silent Shooting mode?.
    • When using the ILCE-9M3 or ZV-E10M2, you can turn off the shutter sound by setting the Audio Signal Volume to 0.
    You can turn off the mechanical and Electronic Shutter sounds by changing the camera settings as follows:
    • When using an ILCE-9, ILCE-9M2, ZV-1, or DSC-RX100M7:
      1. MENU (Camera Settings2) → Shutter TypeElectronic Shutter
      2. MENU (Camera Settings2) → Audio signalsOff or On:other than e-shut
    • When using an ILCE-7SM3, ILCE-7M4, ILCE-7RM5, ILME-FX2, ILME-FX3, or ILME-FX3A:
      1. MENU (Shooting) → Shutter/SilentShutter TypeElectronic Shutter
    • When using an ILCE-1:
      2. MENU (Setup) → Sound OptionAudio signalsOff or On:w/o shutter
    • When using an ILCE-1M2, ILCE-7M5, ILCE-7RM6, or ILME-FX2:
      2. MENU (Setup) → Sound OptionAudio Signal(Shooting)Off or On:w/o shutter
    • When using a DSC-RX1RM3:
      1. MENU (Shooting) → ShutterShutter TypeElectronic Shutter
    Notes:
    • When using the Electronic Shutter, be careful not to violate the subject's privacy or image rights. Use this function responsibly and at your own risk.
    • When using the Electronic Shutter, there are some restrictions on its use and other features that cannot be used simultaneously.
      For details, refer to this article: What are the restrictions on using the Electronic Shutter?.
    For models not listed above
    For models not listed above, especially if it doesn't have an Electronic Shutter, you cannot turn off the shutter sound.
