Article ID : 00107046 / Last Modified : 23/07/2025Print
Sony Compact camera lens is stuck and will not open, retract, or extend
    A compact camera lens that becomes stuck—unable to open, retract, or extend—is typically caused by mechanical or environmental issues.
    We'll list some possible reasons and solutions to get the lens unstuck.
    Physical Obstruction or Debris
    Dirt, sand, dust, or lint can get stuck in the lens barrel or gears. Even a tiny grain of sand can jam the delicate gear mechanisms.
    • Gently check around the lens barrel for sand, dust, lint, or other small particles.
    • Use compressed air or a clean, soft brush to gently remove dirt or debris.
    Impact or Physical Damage
    • The camera accidentally dropped or bumped, causing a misalignment of the lens mechanism.
    • Physical stress can cause the lens barrel to bend or might break internal gears.
    • Internal motors or gears responsible for moving the lens barrel have worn out or failed, especially after prolonged use or ageing.
    • Exposure to moisture or humidity: Moisture can cause internal corrosion or swelling of components, causing friction or mechanical blockage
    If you know this issue appeared after an impact, physical damage, or moisture exposure, a repair is the safest option. Please get in touch with a Sony Authorised Service centre to inspect your camera.
    Low Battery or Power Issues
    A weak or insufficient battery may not provide enough energy to extend or retract the lens fully, causing it to get stuck mid-operation.
    • Check the battery: Ensure the battery is fully charged. A weak or depleted battery can cause lens errors.
    • Remove and reinsert the battery: Turn off the camera, remove the battery, wait at least 30 seconds, reinsert it, and try powering it on again.
    • Reset the camera: You can reset a camera back to the original factory settings by
      • Going into the settings menu options and finding the Initialize or Reset option
      • Depending on the camera model, a small RESET button might be on the camera body itself. To determine your camera's reset or initialisation method, you can easily search the online manuals available on this support website using the words "Reset" or "Initialize."
