Article ID : 00402073 / Last Modified : 21/09/2026Print
    Where to find the power button on your BRAVIA TV (2018-2026 models)
    Looking for the power button on your BRAVIA TV? Use the selector or search box below to find where it's located on your model or series. When checking your TV, look for the power button Power button icon icon. It may be less noticeable on some models.
    Before you start:
    • If you don't know your TV model name, check the serial or terminal sticker on the back of the TV, the TV Settings menu, the original product packaging, or the TV user manual.
    • Can’t find your TV’s power button, or your model isn’t listed? Check the sides, back, front, and bottom of your TV, or refer to your TV's Setup/Startup Guide or Reference Guide, available on the Sony Support website.
    • For 2014-2017 BRAVIA TV models, click or tap here.
    Find the power button location for your TV
