Reset the WF-1000XM5
- Set the WF-1000XM5 units into the charging case.
Note: Leave the charging case lid open.
- Press and hold the reset button on the back of the charging case for about 20 seconds or more.
Hints:- After about 15 seconds, the indicator on the charging case flashes orange for about 5 seconds.
Then, the indicator on the charging case turns off and the headset will be reset. - Do not release your finger from the reset button on the charging case while the indicator is flashing orange. If you release your finger, the headset will be initialized.
- Check that the indicator turns off and then release your finger.
Notes:
- The pairing information and other settings are retained.
- Watch the video to find out how to reset.
Initialize the WF-1000XM5 to restore the factory settings
IMPORTANT: The initialize operation resets all the device settings to the factory defaults and deletes all pairing information.
Notes:
- Delete the pairing information for the headset from the connected device and then pair them again.
- When the remaining battery charge of the charging case is not sufficient, the headset will not start initializing. Charge the charging case.
- Set the headset units into the charging case.
- Press and hold the initialize button on the back of the charging case for about 15 seconds or more.
Hint: The indicator on the charging case repeatedly flashes blue twice in a row, and then the indicator starts flashing orange.
- Release your finger within 5 seconds after the indicator on the charging case starts flashing orange.
Hint: When the initializing is complete, the indicator on the charging case flashes green 4 times.
Notes:
- If the indicator on the charging case does not flash green 4 times after performing step 3, the headset has not been initialized. Try again from step 2.
- You can also initialize the headset using the Sony | Headphones Connect app.
- Watch the video to find out how to initialize.
