For a full list of compatible lenses for your camera, we recommend to use the interactive tool for full compatibility information.
On this website you can cross-reference cameras with different type of lenses and learn if there are any restrictions in usage, or if everything is fully compatible.
To navigate the interactive tool:
- Select your camera model from the list.
- Under E-Mount you will find ILCE and NEX models.
- Under A-Mount you will find DSLR, ILCA and SLT models.
- If you do not know the model name of your camera, click here to learn where it can be found.
- Once you have selected your model you will see all of Sony's and Konica Minolta's lenses that are compatible with your camera.
