Article ID : 00075453 / Last Modified : 16/01/2026Print
    A movie recording does not start even after the Movie button was pressed.
    The camera will not record movies even after pressing the MOVIE button if the Movie Mode Only function is enabled. The Movie Mode Only function prevents the camera from recording movies unless the shooting mode is set to Movie.
    To disable the Movie Mode Only function:
    1. Press the MENU button.
    2. Select Custom Settings.
    3. Select MOVIE Button.
    4. Select Always.
    Example taken from SLT-A99:
    Movie button mode selection
