Article ID : 00140465 / Last Modified : 05/10/2026Print
    What is Remote Camera Control and where can I get it?
    The Remote Camera Control application allows you to operate a camera from the computer using a USB connection. By operating Remote Camera Control installed in your computer, you can change the shooting settings and also capture images. The recorded image data will be stored directly to the computer.
    The Remote Camera Control application can be downloaded from either of these websites:
    NOTE: For details on supported Operating Systems, refer to the above website.
