Applicable Model
This information is for the following model(s):
  • ILCE-7M3
  • ILCE-7M3K
  • ILCE-7M3M
About This Download
Benefits and Improvements
  • Improves the operational stability of the camera
Note: This update is only available for Windows and macOS. A memory card version is not provided.
File Info
  • Name: Update_ILCE7M3V404.exe
  • Version: 4.04
  • Size: 323 MB (339 275 208 bytes)
  • Release Date: 15-04-2026
Preparation
How To: Update Your Sony Camera Firmware
Check the System Software Version
Follow the instructions below to check the system software version:
  1. Select MenuSetup7VersionBody.
  2. The system software version will be displayed.
Notes:
  • If the system software version is Ver. 4.04, the update is not required.
  • If the Date/Time setting screen appears when you turn on your camera, be sure to set the date and/or time to the correct values.
System Requirements
Operating Systems
The latest version of the system software update is compatible with the following versions of Microsoft Windows:
  • Windows 11
Computer Hardware
This system software update requires the following hardware:
  • Intel-based PCs or AMD-based PCs (ARM-based PCs are not supported)
  • Hard drive space: 600 MB or more
  • RAM: 600 MB or more
Note: Please close all other application software before updating the system software.
Power Requirements
  • Power source: Use a fully charged rechargeable battery pack (NP-FZ100).
  • The update can only be performed when the battery power level is (three bars) or more. We recommend you use a fully charged battery.
Other Hardware
  • Detach the vertical grip from the camera before updating the system software.
  • Use the USB cable supplied with the camera.
    Note: Update functionality is not guaranteed with any other USB cable.
Download & Install
Important Notice
  • Close all other application software before updating the system software.
  • Use a fully charged rechargeable battery pack (NP-FZ100).
  • Do not remove the battery during the update as the sudden loss of power may cause the camera to stop working.
  • Remove the memory card from the camera before starting the update process.
  • The system software update will take approximately 10 minutes. Do not allow your computer to go into Sleep mode during this time.
    Note: If the computer does go into Sleep mode and the update is interrupted, the entire update process must be restarted.
  • Do not open About This System Software Updater in the System Software Updater menu as this may cause the software to crash.
  • Do not connect the camera to any device other than your computer.
  • Do not connect the camera and computer at this point.
  • Make sure your computer is connected to the Internet.
  • Follow the instructions in the System Software Updater window:
    1. Select MenuSetup4USB Connection.
    2. Check if Mass Storage has been selected. If a different mode is selected, change it to Mass Storage.
How to Download the Updater:
  1. Click the Download button.
  2. After reading the disclaimer, click Download.
  3. The Update_ILCE7M3V404.exe file will start downloading.
    File Size: 323 MB (339 275 208 bytes)
  4. Save the file to the desktop of your computer (recommended).
    Note: With the default settings of Microsoft Edge, the update file will be saved in your Downloads folder. Click the Desktop tile from the Start screen and use File Explorer to find the downloaded file in the Downloads folder.
Step 1: Update the System Software
  1. Close all programs currently running on your computer.
  2. Double-click the Update_ILCE7M3V404.exe file that you downloaded. Do not connect the camera to the computer at this point.
  3. The System Software Updater will start.
  4. Turn on the camera and connect it to the computer using the supplied USB cable. USB Mode will appear on the LCD screen of the camera.
  5. Click Next. The current version number and updated version number will appear on the lower left side of the screen.
    IMPORTANT: Never turn off the camera or disconnect the USB cable while the update is in progress.
    Note: If the computer cannot find the device, the message “Could not find the camera for this update” appears on the computer screen. Try the following:
    • Disconnect the USB cable and reconnect it.
    • If the computer has multiple USB ports, try a different port.
  6. After confirming that the current software version is Ver. 4.03 or earlier, click Next. If the current system software version is Ver. 4.04, the update is not required. In this case, follow the steps below:
    1. Disconnect the camera from the computer.
    2. Click Finish.
    3. Turn off the camera.
    4. Remove the battery pack.
    5. Reinsert the battery pack.
    6. Turn the camera back on.
    • When the update is required:
      The [Current Version] on the lower left of the screen is showing 4.03 or earlier, and the [Version after the update] is showing 4.04.
    • When the update is not required:
      The [Current version] and [Version after the update] are displayed as 4.04 at the bottom left of the screen.
  7. The camera will reset automatically.
  8. Start the update. After the camera automatically restarts, the update begins and a progress bar appears. The update takes approximately 10 minutes to complete.
  9. When the update is complete, the camera automatically restarts. When the LCD screen appears again, click Finish and disconnect the USB cable.
    Note: After restarting, a data recovery warning may be displayed. This is normal. Wait until the warning disappears.
Step 2: Confirm the System Software Version of Your Camera
Questions & Answers
The Update Does Not Complete
If the camera screen remains black for more than 10 minutes, follow these steps to troubleshoot the issue:
  1. Disconnect the USB cable from the computer.
  2. Remove the battery and AC adapter from the camera, leave them disconnected for a few minutes, and then insert the battery again or reconnect the AC adapter.
  3. Restart the computer.
  4. Turn on the camera and perform the installation process again.
