Applicable Model
This information is for the following model(s):
- ILCE-7M4
- ILCE-7M4M
Required Downloads
Updates should be installed in chronological order!
- For Ver. 1.01 or earlier:
- Update to Ver. 1.05 (available on this page) before proceeding with the Ver. 6.02 (latest) update.
- Update to Ver. 6.02 (latest) after updating to Ver. 1.05
- For Ver. 1.10 or later:
Skip this page and proceed to ILCE-7M4 System Software (Firmware) Update Ver. 6.02.
About this download
This update is only available for memory cards. Windows and macOS versions are not provided.
Benefits and Improvements
This Ver. 1.05 update is an interim version which is required to enable the camera to update to the latest version.
File Info
- Name: BODYDATA.DAT
- Version: 1.05
- Size: 839 741 848 bytes
- Release Date: 24-08-2022
Preparation
How to Update Your Sony Camera With a Memory Card (SD or CFexpress)
Check the system software version
Follow the instructions below to check the system software version. If the system software version is Ver. 1.05, the update is not required.
Note: If the Date/Time setting screen appears when you turn on your camera, be sure to set the date and time to the correct values.
- On the camera, select MENU → Setup → Setup Option → Version.
- The system software version is displayed.
Saving system software data to a memory card
WARNING! Make sure that there is only one BODYDATA.DAT file on the memory card. If you have used the card for a previous update, format the memory card in the camera before downloading a new file.
Insert the formatted memory card into a computer. Save the data in the root directory of the memory card.
Note: Do not change the file name.
Other Hardware
Power source for the camera: Use a fully charged rechargeable battery pack NP-FZ100.
Note: The update can only be performed when the battery power level is (three bars) or more. We recommend that you use a fully charged battery.
Updating the System Software Version
Important Notice
- Use a fully charged rechargeable battery pack (NP-FZ100).
- Detach the vertical grip before updating the system software.
- Do not remove the battery during the update as the sudden loss of power may render the camera inoperable.
- It may not be possible to update if the camera temperature is high. If this is the case, update after the temperature drops.
Step 1: How to download the Updater
- Insert the memory card on which the system software data was saved, into slot 1 of the unit.
Note: Only slot 1 recognizes the system software data. - Select MENU → Setup → Setup Option → Version and select Software Update.
- Select Execute on the system software update confirmation screen, and the update starts.
Notes:- A Version Update X.XX → Y.YY message appears (X.XX = the existing version number, Y.YY = the latest version number).
- Do not remove the battery and the memory card during the update.
- When the system software update starts, a black screen is displayed and the access lamp flashes. The access lamp flashes 1 time → 3 times → 5 times depending on the progress of the update. The update will take approximately 6 minutes to complete.
Notes:- If the system software data copy is incorrect, The target model for the update file is incorrect. will be displayed on the monitor of the camera.
- If the access lamp repeats 5 long blinks (0.5s cycle) and 6 short blinks (0.25s cycle), the system software may not have been copied correctly to the memory card. In this case, remove the battery and memory card from the camera, and start over at Saving system software data to a memory card.
- When the update is completed, the camera will automatically restart. After restarting, when the Body update complete screen appears, press OK.
Step 2: Confirm the system software version of your device
- You can now proceed to update the software to the most recent version.
